Old 10-Feb-2014, 12:07 AM   #3
My evaluation of your reception situation is the Tv signal strengths of the strong signal strength Tv stations ,
Are Not so strong as to over load a Tv tuner.
Your reception situation has many strong signal strength Tv stations and 2 Tv stations that are the odd ones out.
WGTV-DT , Real VHF high band channel 8 , PBS.
And.
WPXA-DT , Real UHF channel 51 , ION.
WGTV-DT channel 8 , is strong signal strength , however has 2 Edge path obstructions and is off in it's own direction.
WPXA-DT channel 51 , is Weak signal strength , and has 2 Edge path obstructions.
I recommend Test reception with a , Antennacraft.net , HBU22 antenna aimed at about 328 degree magnetic compass direction.
Test reception with No antenna system amplifier.
Connect a New Continues length of coax to the HBU22 antenna and run the New Continues length of coax throught a open door or window direct to 1 Tv , No splitters , No amplifiers , No couplers , No etc. .
WGTV-DT channel 8 is a strong signal and should be received.
And the Tv stations in the other directions are strong signal strengths and should be received.
Directional antennas such as and not limited to the HBU22 antenna , receive the best at the front of the antenna , a little less at front angles to the antenna , and less at back angles to the antenna and less at back of the antenna.
And the least amount of signal directly on the sides of the antenna.
Install the HBU22 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv stations of other directions will be received at angles to the HBU22 antenna.
www.ronard.com/909911.html
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
