Directional antennas such as and not limited to the , HBU55 and HD7698P antennas receive the best in the forward direction , a little less at front angles to the directional antenna , less at back angles to the antenna and less at the back of the antennas.
Directional antennas such as and not limited to the , HBU55 and HD7698P antenna have the least amount of reception , directly on the sides of the antennas.
The Current Tv channels that are being transmitted and received on the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable Digital Broadcast Tv Stations/Channels in the VHF high band and UHF band.
An Example and not the only example is.
WESH-DT , Real VHF high band channel 11 , virtual number (2.1) , NBC .
Is Weak signal strength at , 11 NM(dB) .
Has 1 Edge signal path obstruction.
And is 68.1 miles distant.
The HBU55 and the HD7698P antennas are Big antennas and as such will receive More signal.
Antennas such as and not limited to the HBU55 and HD7698P antennas are designaed to receive the VHF high band channels an UHF channels.
The HDB8x and other antennas like it such as the Antennas Direct DB8e , are deigned to receive the UHF channels.
And have a small amount of reception of the VHF high band channel 7 thru 13
A small amount of VHF reception will not work for your reception situation , your reception situation requires a antenna with a high amount of antenna gain for the VHF channels.
