Old 9-Feb-2014, 2:02 AM   #1
K-Rock
trying to get an antenna setup in atlanta
http://www.tvfool.com/?option=com_wr...5b9467dc5889d4
Trying to come up with a good setup for a new OTA. The main locals at the top, real 8 and to a small degree 22 are what I want to receive and I guess ION if it does not start to pose a problem. Being that everything is green I have been trying to hit some thrift shops to try and find some cheap 2 dollar rabbit ears just to see if thats all I would need. In the report I listed it at 15 feet as I have read people using two fencing poles driven into the ground to mount on and thought about that. I do not have attic space and am not wanting it on my roof as I would be doing it and don't really want it visible though am not completely opposed to it as it would cut a $70 cable bill with noting but digital starter from comcast. I have a tree forest to deal with in the back (read blocking all the channels I want), and a large magnolia in the front blocking channel 22. Attached is a picture showing the general direction of the main cluster of transmitters, channel 8 is roughly behind me taking the pic, and to the right is the magnolia tree.
EDIT: Just to add a little clarification, I had planned on putting the pole in the back as I said to keep some what hidden as I know it has to come over the roof to pick up other channels. I thought about the opposite end of house from the picture but then realized the magnolia tree is in the way. Maybe the other end or on the carport as its not used for car anyway and any screw up on install wont affect the inside of the house if height is needed.
Last edited by K-Rock; 9-Feb-2014 at 2:59 PM. Reason: Just a little more clarification
K-Rock is offline   Reply With Quote
