Greetings Free1,
Edit: If you are in Hillsboro, can you rerun your TV fool plots at 50', 75' and what you consider the height of your trees? I ran a generic plot off your zipcode and it reports Line of sight conditions to Portland transmissions.
I want to see if elevation improves your conditions dramatically. If so, you can go higher with a tree mounted antenna that is smaller than the monster HD1800. However, let's see what your reposting says.
SS
