Old 8-Feb-2014, 4:17 AM   #6
Now that you have had some time to think about the reception situation and the recommended antennas.
As a Test of reception.
With the DB8e installed it might be possible to receive the USA and Canada Tv stations with the 1 DB8e antenna.
1 panel of the DB8e antenna is used to receive the USA Tv stations in both directions , remove the reflector screen from 1 panel.
The other panels reflector screen is not removed and the panel is aimed the Canada Tv stations.
The signal strengths of the Canada Tv stations are weak signal strength , the only way to find out if the 1 panel will receive them is install the DB8e in a location that has the least amount to no amount of obstructions on the directions of reception and Test reception.
