Old 8-Feb-2014, 3:46 AM   #3
The Digital Broadcast Tv reception is Strong Signal Strength at your reception location.
Even with the strong signal strengths.
I Strongly recommend install the UHF bow tie antenna above the roof in such a manner that reception is not , obstructed , impeded , blocked , buy the , attic , roof , and building in the directions of , North East and North West.
The UHF 4 bay bow tie antenna is designed to receive the Current UHF channels 14 thru 51.
However VHF high band channels are strong signal strength and if the UHF antenna is installed at a unobstructed location , channels 9 and 11 will most likely be received reliably.
Aim the UHF 4 bay bow tie antenna at a in between aim direction of the Tv stations to the North East and North West.
Aim the antenna at about 25 degrees magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a areal and Actual magnetic compass to aim antenna.
Here are chimney antenna mounts.
www.ronard.com/ychim.html
www.ronard.com/34424560.html
Use the the , ronard(4560) , eave antenna mount.
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
A Winegard , DS3000 , J pole type antenna mount works Ok for a antenna mount.
If the 4 bay bow tie UHF antenna does not receive reliably , then install a , Antennas Direct , C5 antenna aimed at about 25 degree magnetic compass direction , above the roof.
The C5 antenna has a very wide reception direction pattern of the VHF and UHF channels.
The C5 comes with a VHF/UHF combiner , the combiner will not be used when the C5 is connected by it's self.
A antenna system amplifier is not required , the signal strengths of the Tv stations are strong.
www.amazon.com
Last edited by teleview; 13-Feb-2014 at 11:43 PM. Reason: Clarify information and typos.
