Old 7-Feb-2014, 11:42 PM   #4
technicolor
Originally Posted by No static at all View Post
You will have to try both NY & Philadelphia to see which provides the most reliable ABC station. Hard to say which will work best w/o actually trying.
As Teleview mentioned, a rotor would not be a good solution. It would just take too long to rotate the full 180° between the 2 markets.
Good luck!!
Thanks for the great advice. I checked the maps, it looks like the ny abc has me in the blue/borderline violet zone. Clearly having something pointing out a window would be able to remotely get a signal.
I'm pretty confident at this point the hd1850 in a good roof location will be able to hit it.
technicolor is offline   Reply With Quote
