I am recommending the DB8e antenna not the DB8 , C4 or 91XG.
Reason for the DB8e antenna is.
Tv signals over distance and tending to bend over hills and mountains , make the Tv signal shift and move up and down and side to side.
The Big Broad Flat Upright Surface of the DB8e antenna will have reception elements in the signal path as the signal shifts up and down and side to side.
Reason: Clarify information and typos.
