Old 7-Feb-2014, 8:53 AM   #2
--->Above The Peak of the Roof install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna from , www.amazon.com .
And aim the DB8e antenna at about 140 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Above the Peak of the Roof install a , www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 anten a aimed at about 350 degree magnetic compass direction.
Install a , RCA , TVPRAMP1R , preamplifier.
Operate the RCA preamp in the Separate antenna mode.
The FM radio trap switch will be in the , on/in position.
Connect the DB8e , UHF antenna to the UHF connection of the RCA preamp.
Connect the Y10-7-13 VHF antenna to the VHF connection of the RCA preamp.
For 3 Tv's connected use a , Holland Electronics , HFS-3D ,3 way splitter.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandectronics.com , of , www.amazon.com .
Here are some Above The Roof Antenna Mounts.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2219) , ronard(2224) .
As always , trees and tree leaves have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof and building.
Absorbing and Blocking Reception.
Multi-Path Reflections Tv Signals Bouncing All Around.
The Brst Pratice is to install the , DB8e antenna and the Y10-7-23 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception , South East and North.
Last edited by teleview; 7-Feb-2014 at 9:38 PM. Reason: Clarify information and typos.
