Old 7-Feb-2014, 4:07 AM   #2
For Reliable reception install a , www.antennacrft.net , HBU44 antenna aimed at about 150 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a , RCA , TVPRAMP1R preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com
www.ronard.com/909911.html
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
As Always , trees and tree leaves , plants and plant leaves have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and Blocking Reception.
Multi-Path Reflecting Tv signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
The directions of reception are , South West , West South West , East.
