Thread: Missing Station
Old 6-Feb-2014, 5:08 PM   #3
The , Current Plus Pending Applications Included Tvfool Report is what I Reference.
The provided tvfool report is not showing any antenna height above ground.
Do not delete the the report that is not showing any antenna height above ground.
To see if any more Tv stations will be received , please make and post 3 more Tvfool reports at , 25 , 40 , 60 , feet antenna heights above ground.
For Accurate reports of your reception location please use your Exact address to make and post reports.
If your exact address does not work.
Then go to the Tvfool home page and Click On , >>Start MAPS<<.
Select a location as a starting point , and Move The Pointer to your Exact Location.
Make and post the Tvfool reports of , 25 , 40 , 60 , feet antenna heights above ground.
Last edited by teleview; 6-Feb-2014 at 11:46 PM. Reason: Clarify information and typos.
