Old 4-Feb-2014, 7:53 AM   #3
Aim 1 panel of the DB8e , UHF channels 14 thru 51 , antenna at about 10 degree magnetic compass direction.
Aim the other panel of the , DB8e antenna at about 326 degree magnetic compass direction.
Aim the , Y10-7-13 VHF high band channels 7 thru 13 antenna at about 345 degree magnetic compass direction.
Most Digital Broadcast Tuners have a , Signal Strength Meter and some Digital Broadcast Tuners all so have a , Signal Quality Meter .
Signal Quality is Important.
As Always , the antenna aim direction and location of antenna can be adjusted for best reception.
