Old 4-Feb-2014, 7:17 AM   #6
The Current Tv channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has receivable Tv channels in All 3 Bands.
The reception signal strengths are Weak Signal Strength at your reception location.
Recommend install a , Large All Channel Antenna.
Above The Peak Of The Roof install a , www.antennacraft.net , HD1800 All channel antenna aimedat about 29 degree magnetic compass direction.
Install a , www.channelmasterstore.com , CM7778 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
www.ronard.com
www.amazon.com
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadvast Tv Stations Channels, often named the ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels~.
Scan for the , ATSC-Digital Broadcast Tv Stations/Channels.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception with a Tv Antenna and so do buildings and other obstructions including your own roof and house.
Absorbing and Blocking Reception.
The Best Pratice is to install the HD1800 All Channel Antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception including your own roof and house.
