You will need to identify the specific configuration you have connected. You've mentioned several different amps but you've not defined the current configuration for status updates so, without specifics, advice may be based on assumptions from prior statements.
Individual antenna tests, not combined, assuming no amplifier installed:
1) Does the C2V reliably pick up everything except WRBK?
2) Does the 91X reliably pick up WRBK (ignore all other channels)?
If the answer to both #1 and # 2 is "Yes", then combine the antennas using the reversed splitter and re-evaluate reception for ALL received channels.
Are all channels reliable now?
If "yes", you are done.
If "no" and the 'problem' channel was previously reliable with the individual antenna, you need the AC7 combiner.
