Old 3-Feb-2014, 7:28 PM   #5
Their are better antennas then the Winegard 8800 antenna.
Find antenna comparisons at , www.antennahacks.com .
For better reception install a , www.channelmasterstore.com , CM4228HD antenna aimed at about 200 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a , RCA , TVPRAMP1R , preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandrctronics.com , or , www.amazon.com .
Here are some Above The Peak Of The Roof Antenna Mounts.
www.ronard.com/909911.html
Use the , ronard(2212) , 5 foot tripod antenna mounts.
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
