Old 3-Feb-2014, 7:06 PM   #15
Originally Posted by bid74 View Post
I want to thank both ADTech and Teleview. I mounted the Db2e above our top roofline and pointed it 310 degrees (Northwest) and it worked very well as we picked up 62 channels. The only channel that comes in weak is KGO, channel 7. Any suggestions on fixing that or do I need to switch antennas?
Thanks.
Before changing or adding an antenna, have you exhausted mounting location and aiming variation options? If you have thoroughly experimented with all the available possibilities, added H-VHF performance can be had in the Antennas Direct CS5, Antennacraft Y5713 & Y10713. These options would replace the VHF dipole... not the CS2 UHF loops.
