Anyone have any explanation for this?
I know the amplifier I use isn't supposed to actually enhance the quality the antenna picks up, but this doesn't seem to be the case. If a signal is breaking up, I've discovered elevating or moving the amplifier seems to help it come in. Not sure if it's from the cable movement slightly moving the antenna or if the location of the amp actually helps with reception.
