--->For reception of those Tv stations you will like to receive.<---
------->It is Important <-->to avoid obstructions in the directions of reception.<------
Obstructions such as and not limited to , attic , roof , buildings including your own , attic , roof and building and trees , cause Multi-Path reflections Tv signals bouncing all around.
Your reception location has some strong signal strength Tv signals and strong signal strength Tv signals bouncing all around is not good for reception.
Digital tuners can correct multi-path to a certain point , and then the multi-path is Too Much multi-path and Too Much strong signal strength multi-path.
The Digital tuner is overloaded with multi-path and this will be the cause of bad reception of some channels.
It is important to avoid obstructions to reception such as and not limited to , attics , buildings including your own building , trees and tree leaves , plants and plant leaves and other obstructions.
Install the HBU11 at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building in the directions of reception.
Reason: Clarify information and typos.
