Old 3-Feb-2014, 7:56 AM   #3
StephanieS
Hello TBK,
I would second Teleview's suggestion and choice of equipment with only one minor addition.
For the DB8e, since your stated reception goals are for Hartford specifically in WVIT, WTNH, WTIC and WFSB. I would focus both panels at towards magnetic 308 degrees. This would allow you to use the DB8e's gain to your highest advantage for the Hartford signals at 302 and 315 magnetic.
If you want to receive MyNetwork WCTX, then orientate DB8e as per Teleview. If you want to focus on the major networks, orientate as I suggested.
For the Y10-7-13, magnetic 260 for WTNH per Teleview.
Use preamp as recommended.
Cheers.
