Hi Mark,
Wish I could've been a bearer of better news.
Teleview suggests the Antennacraft HBU11K, for locals I might have suggested that antenna too. Instead of outdoors which would be normal, I would, and this is an uncommon suggestion for me - if you have an attic I would test mount it in there. My thinking here is that I want to knock down KGBT's signal strength using the attic (if you have one) to attenuate the signal for RF 31, that might be a good thing.
Do you have trees on your property? Or can you literally see the broadcast tower(s) from your roof?
Regards.
