Old 3-Feb-2014, 4:31 AM   #2
Above The Peak Of The Roof install a , Antennas Direct , DB8e , UHF channels 14 thru 51 antenna.
Aim 1 panel at about 335 degree magnetic compass direction.
Aim the 2nd panel at about 260 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Also Above The Peak Of The Roof install a , www.antennacraft.net , Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 260 degree magnetic compass direction.
Install a , RCA , TVPRAMP1-R , preamplifier.
Connect the DB8e , UHF antenna to the UHF connection of the RCA preamp.
Connect the Y10-7-13 , VHF antenna to the VHF connection of the RCA preamp.
Operate the RCA preamp in the Separate antenna mode.
Have the FM trap in the in/on position.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com
Here are some Above The Roof antenna mounts.
www.ronard.com/909911.html
Use the , ronard(911) , 5 foot tripod antennas mount.
www.ronard.com/34424560.html
www.ronard.com/ychim.html
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com
The Tv Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv's transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels ~.
Channel scan for the , ATSC-Digital Broadcast Tv Channels.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
Negative Effects sich as and not limited to.
Absorbing and Blocking Tv Reception.
Multi-Path Reflections Signals Bouncing All Around.
The Best Pratice is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
