Old 2-Feb-2014, 4:51 AM   #11
The Current Tv Channels that are being transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has Tv channels in All 3 Tv channel bands.
The Tvfool Digital Current Plus Pending Applications Included Channel List and Radar Report.
Shows Real channel 3 , WBRA-DT 3 , PBS , at 161 Degree magnetic compass direction.
Aim a , www.antennacraft.net , Y5-2-6 antenna , channels 2thru 6 antenna at about 161 degree magnetic compass direction.
For reception of , WVNS-DT Real channel 8 , CBS and Fox and MyNetwork.
Aim a , www.antennacraft.net , Y10-7-13 antenna , channels 7 thru 13 antenna at about 320 degree magnetic compass direction.
Connect the , Y5-2-6 antenna and the Y10-7-13 antenna together with a , HLSJ= High band / Low band /Separator-Joiner. Buy the , HLSJ , at www.solidsignal.com .
A warning about solidsignal , Do Not engage in discussion about what antennas are for your reception situation.
You will receive advice that will not be correct.
Get your HLSJ , and get out the door fast.
Connect the Y5-2-6 low band antenna to the low band connection of the HLSJ.
Connect the Y10-7-13 high band antenna to the high band connection of the HLSJ.
The remaining connection of the HLSJ is connected to the VHF connection of a ,
RCA , TVPRAMP1R , preamplifier .
For reception of , WVVA-DT , Real UHF channel 46 , NBC and CW and Me-Tv .
And for reception of , WLFB , Real UHF channel 40 , religion.
Install a , AntennasDirect , DB8e , UHF channels 14thru 51 antenna aimed at about 253 degree magnetic compass direction.
Connect the DB8e antenna to the UHF connection of the same RCA preamp.
The RCA preamp is operated in the Separate VHF/UHF Antennas Mode.
With this setup a antenna rotator Is Not Required.
One coax down lead goes in to the house from the RCA preamp.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing/html .
www.amazon.com
For 1 Tv connected use No Splitter.
Buy the , HFS-2D and HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
Last edited by teleview; 4-Feb-2014 at 1:58 AM. Reason: Clarify information and typos.
