Old 28-Nov-2010, 2:48 AM   #2
Dave Loudin
There seems to be plenty of signal at your location for an indoor antenna. However, if there's lots of metal in the walls, like to support stucco, then all bets are off. Try the Terk HDTVi, which has integrated rabbit ears. You need those for PBS and ABC, as they are on high-VHF channels (look at the Real Channel column). Do NOT buy an amplified antenna, as you will be throwing money away on something you don't need.
If you can only find the HDTVa, you can disable the amplifier, but you have to leave the unit plugged in.
