Old 1-Feb-2014, 2:24 AM   #25
mulliganman
If you have the CM3410, then change it out. It can only help. Might not make a difference, but the only way to know is to try it.
Have you tried merging the 91XG with the C2V using a reversed splitter? If that is successful while causing no ill effects (lost channels, etc), then the AC7 combiner won't be needed. If combining the antennas with the reversed splitter does cause problems, then the AC7 is definitely called for.
I tried the CM3410 and didn't see much difference. Fox KRBK would bump up to 80 percent signal strength for a brief moment before returning to 79 percent. On the Skywalker Fox will dip to 77 percent for a bit before bumping back up to 79 percent. I'm kind of surprised by this.
I'm not real familiar with what a custom combiner is. Is it just to reduce interference? Anything I need to know about installing it when it comes in? Thanks again.
