Old 1-Feb-2014, 1:17 AM   #4
The No antenna rotation solution.
No antenna rotation required for reception at your location.
Up high , install a , Antennas Direct , DB8e , antenna.
From , www.amazon.com .
Aim 1 panel at about , 10 degree magnetic compass direction , a in between a aim direction for reception of the Tv stations to the , North West and North East.
Aim the other panel at about 225 degree magnetic compass direction for reception of the Tv stations to the , South West.
Install a , www.antennacraft.net , Y5-7-13 antenna aimed at about 30 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Install a , RCA , TVPRAMP1R , preamplifier.
Connect the DB8e to the UHF connection of the RCA preamplifier.
Connect the Y5-7-13 to the VHF connection of the RCA preamplifier.
Operate the RCA preamplifier in the Separate antenna mode.
Have FM trap in/on.
For 2 Tv's connected use a , Holland Electronics, HFS-2D , 2. Way splitter.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception with a Tv antenna and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
Multi-Path Reflecting the Tv Signals Bouncing All Around.
The Best Pratice is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind on the directions of reception.
www.ronard.com/909911.html
www.ronard.com/Tripods%200703/4712.html
Use the , ronard(4712-50-10) , 10 foot tripod antenna mount.
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
www.ronard.com
www.amazon.com
For antenna mast , Home Depot and Lowes have 10 foot sections of , Top Rail , chain link fence pipe. The price for the Top Rail fence pipe is low dollars.
As to the Internet.
In the google search box type in.
wireless Internet providers linden nc
And
internet providers linden nc
Last edited by teleview; 3-Feb-2014 at 4:29 PM. Reason: Clarify information and typos.
