Old 1-Feb-2014, 12:07 AM   #3
jmc1987
First off, never post your address on a forum publicly. The TV Fool report is good enough and conceals your address for this very reason.
Honestly, I'm a bit of a novice myself and only signed up recently to figure out if using an indoor antenna (which is a dirty word here) would work for my situation, but from looking at your report, I think you'll be fine with an outdoor antenna at just about any height. Almost all the stations in green have line-of-sight signals coming in strong enough to pick up with an indoor antenna. In my apartment, I only have 1-edge and 2-edge signals (meaning lots of interference) and I was able to get several with an indoor antenna only 6 feet or so above ground.
An outdoor antenna pointed North at 10 ft high will get you just about everything in the top 10 channels listed on your report. Unfortunately, I've spent about all of my expertise here, so someone else will have to weigh in further.
jmc1987 is offline   Reply With Quote
