Old 31-Jan-2014, 10:03 PM   #2
Above the Peak of the Roof install a , www.antennacraft.net , HBU11K antenna aimed at about , 129 degree magnetic compass direction.
Recommend avoid using a antenna system amplifier because of the Very Strong local Tv transmissions.
Those Strong local transmissions can overload a signal amplifier and be the cause of bad reception of some channels.
As is with All reception situations , avoid obstructions to reception in the directions of reception.
Avoiding obstructions is important if you will like to receive the Weak Signal Strength Tv stations.
Test reception with only 1 Tv connected , No splitters.
Digital Tv tuners can develop -Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
www.wchstv.com/DoubleReScanAlert.pdf
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Signal Quality is Important.
Last edited by teleview; 6-Feb-2014 at 3:30 PM. Reason: Clarify information and typos.
