Old 31-Jan-2014, 7:21 AM   #10
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Pratice is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Cable Tv delivered services of any type or kind , be it , cable Tv service , cable delivered Internet service , cable delivered phone service , Must Not and Can Not be connected to the antenna or coaxes that are used for the antenna system.
Any type or kind of cable delivered service Must Be on a Separate Coax.
Some satellite systems will accept and distribute the antenna system signals and some satellite systems Will Not.
If you do not have satelite service now.
Then disconnect and remove All satellite system components such as and not limited to , multi-switches , multi-plexers , amplifiers , power inserters , power supplies , splitters , couplers and etc. .
Yes , coax that was part of the cable or satellite services can be used for the antenna system.
I recommend a antenna that will do a better job of receiving Tv transmissions of other directions.
Will receive the UHF channels 14 thru 51.
And will also do a better job of receiving the VHF high band channels 7 thru 13.
Install a , ANT751 antenna , www.amazon.com .
Home Depot or Lowes can have the ANT751 antenna in the store no matter what the Home Depot and Lowes web sites say.
Or install a , www.antennacraft.net , HBU11K , antenna.
Aim the , ANT751 antenna or HBU11K antenna at about , 350 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Last edited by teleview; 3-Feb-2014 at 6:09 PM. Reason: Clarify information and typos.
