Old 30-Jan-2014, 8:21 PM   #5
StephanieS
Hi adk7108,
Welcome to the forum!
Before we can really help some details about your situation may be helpful. What channels do you want? What is your desired outcome? What is your coax set up? Are you splitting to several tvs? What kind of antenna specifically are you using?
Before I get too deep, trees are bad news. If you are shooting through trees to receive a signal your results can be varied and seasonal. Think summer = leaves = more chances to reflect, scatter and deflect signals. This can make even strong signals prone to drop outs.
Your report is doable, but has some challenges. I suspect with the right set up you could receive ABC, NBC, CBS an FOX.
Just for curiosity sake, rerun the TVfool plot at 50 and 75, seeing if there are any differences.
My first instinct to you is get above the trees. That will improve chances of reliable reception given that you likely need a strong set up without the trees for reliable reception.
