Old 30-Jan-2014, 6:07 PM   #18
roadrunnerray
Swap out the coax from the splitter to the Samsung for troubleshooting purposes.
Some of the RCA amps have flaky switches. Keep an eye out for that. Try it with the FM filter switch in both positions to see if that makes any difference.
Thanks ADTech. I will first swap out the cable. The RCA amplifier sends the VHF/UHF signal to the other 2-TVs fine although they seem a bit weaker. Is there a signal booster I can add where the cable comes into the garage?
Edited to add, I just checked the other 2-TVs and they are now not receiving the VHF signal.............
I will check the VHF antenna.
Edited to add, the VHF signal seems to be coming inOK at night but fading during the day. Does this make sense??
roadrunnerray is offline   Reply With Quote
