Correction, we do not get the "real" channel-6 but virtual channel 6-1 and 6-2 which is UHF channel 23. I will check the switch and get back to you..........
I just checked the RCA pre-amplifer and the switch is set to "separate." The FM trap switch is set to "."
I reconnected the cables to the pre-amp and lo-and-behold I am now getting the VHF channels. I may have had the VHF antenna cable hooked into the UHF post on the pre-amp.
Many thanks for your kind help.
One last question, what does it mean after I do an auto-program for channels when the message comes up "mode not supported?"
