Old 29-Jan-2014, 8:23 PM   #14
roadrunnerray
Make certain you opened up the amp and switched it to the "separate" input setting.
Channel "6", if received in HD, is a UHF station transmitting from Tijuana. I don't recall if their analog channel 6 signal is still on the air or not.
I did check the switch but will check it again.
We get channel 6-1 in English and Channel 6-2 in Spanish.
Thanks for your thoughts.....
roadrunnerray is offline   Reply With Quote
