Old 28-Jan-2014, 1:52 PM   #1
daveinmaryland
Maryland attic antenna help
Recently purchased new home. Want any help I can get with this install.
TVFOOL
http://www.tvfool.com/?option=com_wr...5b946b9151e4d1
So, a bit about the home. Home was built in 2006, wired with structured cable with 2 quad shielded RG6. All the rooms are hooked up, and wired to a common patch panel on the first floor.
Home faces almost dead east, so, the north face of the attic is a wall, 2 x 4 studding, sheathing, vinyl siding. The attic is tall, however, has those modern trusses, with the "w" bracing, 24" on center. Because most of the stations in DC are at ~337, with the wall pretty much facing due north, I think antennas will go in and work just fine.
Plans are to hook up two devices, TV in the living room, home theater on the second floor. The antenna(s) will be connected to the knee wall jack in the rear of the home theater room (closest and easiest to access). At the patch panel, I will identify the cable to the antenna(s), to the home theater box (? help here), and to the living room cable. All other cables will be disconnected.
So, the help I would like, recommendations on antenna(s), amps, mounts, and the box (sorry, mind isn't coming up with a better word, for the home theater, I need the box to hook up to the RG6 from the antenna(s) to the receiver for the projector in the home theater).
The home is on a very flat piece of property, with very few trees for about a mile. The attic floor is about 22' off the lawn level.
Not sure what else I can offer up to help myself.
Thanks in advance, I appreciate the help. I just can't see paying the $185.00 to the cable company that I was at my last place.
daveinmaryland is offline   Reply With Quote
