Old 28-Jan-2014, 1:04 AM   #16
mulliganman
Ok I have some additional information about equipment used.
Here is the preamp being used: http://www.winegard.com/kbase/upload...20_HDP-269.pdf
Here is the distribution amp being used: http://www.skywalker.com/Products/Sk..._SKY38323.aspx
I have been unable to attain the model for the short range directional antenna and have had no luck with HAM radio. I have been in discussions with Antenna Direct and they have suggested a couple of options.
Option # 1: Pairing the C2V with the Antennas Direct DB4E as a two antenna setup with the DB4 dedicated to KRBK Fox (possibly with a preamp; either the one used or another suggestion) and a distribution amp.
Option #2: Using the Antennas Direct DB8E as a single antenna solution. Not sure about a preamp but utilizing a distribution amp.
and VHF reflector: http://www.antennasdirect.com/store/...-Assembly.html
I am running the signal to 3 TV's with a Holland splitter. ABC, NBC, CBS, PBS, CW come in without issue via the C2V.
Here are the locations of the Fox KRBK towers (the KWBM piggyback channel near Branson isn't shown): http://www.rabbitears.info/contour.php?appid=1495755
I would appreciate any thoughts about both, amps (including those being used), etc.
mulliganman is offline   Reply With Quote
