Old 27-Jan-2014, 12:18 PM   #10
Mrbowtie26
Ok so aiming each DB8 side @ the appropriate heading (189, and 26 degrees) got me about 32 channels which I am pretty happy with. I was wondering if I wanted to get a bit more flexibility in how many I pull in how would I go about installing another DB4 or another DB8 to basically get full coverage ? I wasn't sure if you can install another DB8 and run both DB8 lines into a combiner before the pre amp. And if so I would assume the lines need to be the same length, and do I need to mount it a certain distance below or above the original DB8 on the mast ?
Thanks for the help !!
Ron H.
Mrbowtie26 is offline   Reply With Quote
