Old 27-Nov-2010, 4:32 PM   #1
bmelanco
Not pulling in the stations I should -need advice
Hello
I seem to not pull in some of the stations I should be Including some key ones that either are unreliable or don't come in at all. Here is what we have for equipment:
 Winegard HD-9032 UHF HD TV Antenna ProStar HD9032 35.
 Channel Master 9521A Antenna Rotator Remote Control Automatic System Rotor Complete 9521-A Remote with IR Head Controller.
 Winegard AP-4800 ChromStar 2000 UHF Pre-Amplifier AP4800 HDTV Antenna Booster Outdoor Off-Air Television Aerial 75 Ohm Signal Preamplifier VHF By-Passed / UHF 28 dB, 117 VAC.
 RG-6 Quad Shield Coaxial Cable RG6 3 GHz Copper Clad Black Satellite Double Foil 18 Gauge Audio Video HDTV Digital Signal Distribution Network Component.
 Channel Master 3064 75' FT Rotor Wire Cable 3 Conductor CM3064 Antenna Automatic 22 Gauge TV Rotator Cable for CM9521
and here is where we are:
http://www.tvfool.com/?option=com_wr...81a39874e2faf0
and here is what we get (it has been a year or so):
The channels we always get are: 43.1, 3.1, 24.1, and 68.1 (almost always).
We sometimes get: 9.1, 15, 5.1.
We never get" 2.1, 38.1, 33.1, 20.1, etc.
I thought I'd be able to get all my "green" and "yellow" stations and bring in at least some of the "red" stations. I have thought about just raising the antenna? I think I have a UHF only antenna and wondered if this might be the problem?
Any help is appreciated.
Thanks
Brian
bmelanco is offline   Reply With Quote
