Old 26-Jan-2014, 8:41 PM   #2
I'd start with the Boston signals. To maximize the opportunity I'd use either an Antennas Direct DB8e or 91XG. Start with the aim basically due south and fine tune it from there.
If you wanted to add WMUR or WENH, an Antennacraft Y10713 can be added.
How many TVs will be connected? How long a run is it from the antenna to the most distant TV... as the cable runs?
