I suspect that a smaller antenna would be needed if mounted a bit higher, above the peak of the roof. You can test that theory for free, just run a TV Fool report for the higher elevation...
In the attic, I'd agree that a lager antenna as suggested by teleview would be appropriate. In the end, attics can be awful locations for reliable reception.
