Old 26-Jan-2014, 5:02 PM   #5
SnowB0und
KTVU is quite a 'long shot'. Not because of the distance, but because of the terrain between their transmitter and your location.
If I was intent on doing what ever it took to receive KTVU, I'd start by mounting an Antennas Direct 91XG outdoors, in the clear. Should that fail, I'd be thinking of building a dual or quad stack of identical antennas... This would be a case that may well require 'extreme measures.
Thank you for the input! That is what I figured. I believe KTVU comes from SF and there is a (almost) 1000 hill between here and there. I feel that going through all of that effort would cause me to lose the majority of the channels coming from Sacramento as they are almost 180* from each other.
SnowB0und is offline   Reply With Quote
