Old 26-Jan-2014, 4:27 PM   #8
The coax can also be fed up through the bottom of the mast pipe and out the top of the mast pipe.
This keep the coax from swinging in the wind.
Do Not use vinyl electrical tape on outside connections , vinyl elictrical tape Does Not seal well and Will Take In And Hold Water At The Connection , holding water at a connection is Not Good.
