Thread: Mohu Sky
Old 26-Jan-2014, 4:06 PM   #6
Here are some Above The Peak Of The Roof antenna mounts for the larger antennas , C490 and HD1200.
www.ronard.com/909911.html
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2225) .
Buy the ronard antenna mounts at , www.ronard.com , or , www.amazon.com .
Tv stations to the , East and West and other directions will be received.
No antenna rotator is required.
Tv antenna rotation is Real Close to Zero Fun , must wait for antenna to rotate and their Will Be Domestic Situations about the direction the antenna is aimed.
The coaxes that are that are in and on the building can be used for the antenna system.
If you will have any type or kind of of active cable delivers service , cable Tv service , cable deliverd Internet service , cable deliverd phone service , the cable delivered services Must Not be connected to the coaxes that are used for the antenna system.
Any type or kind of cable service Must Be on a Separate Coax.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcat Tv Channels , often named the ~ Antenna Channels ~ DTV Channels ~ ATSC Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ DTV Channels , ATSC Channels ~ Air Channels~.
Channel scan for the ~ ATSC Digital Broadcast Tv Channels.
