Old 26-Jan-2014, 6:08 AM   #2
The antenna is a , Antennas Direct , CS2V , UHF/VHF antenna.
For Reliable Reception.
Install the antenna Above The Peak of the Roof.
Aim the antenna at about 50 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compas to aim antenna.
When the CS2V antenna is installed Above The Peak Of The Roof.
Install a , RCA , TVPRAMP1R , preamplifier.
Yes the preamplifier can be installed when the antenna is setup inside the building and attic.
----> HOWEVER Know This ,
Antenna system amplifiers Are Not a Cure All for indoor Tv reception.
Attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Buy the , HFS-2D and HFS-3D , splitters at.
www.hollandelectronics.com
Or
www.amazon.com
Last edited by teleview; 28-Jan-2014 at 12:42 AM. Reason: Clarify information and typos.
