Wow!! Thanks for the help!! I only recently found this website. Very cool!!
Just looked at the above suggestions. As you can tell I'm new at this. Going to take a little to digest the info. 93 degrees is toward Philly, but what about the stations west and south? I do have a tree north and south, so east/west is relatively clear.
Too far?
Do I get a motor to rotate?
Maybe 2nd antenna? If so how far apart do they need to be? or above/below each other?
What would be a 'long' cable run? to need an amp. There is a junction block in the basement currently used by cable. Once the cable is gone, could I use that?
Alot of questions...sorry. Thanks for all your help.
