Television Reception
Television transmissions spread this far apart in two separate directions means that a Tv antenna with a rotor or a two antenna solution with a remote control A/B switch. So the question is , how many tv's will be connected ? If one tv then a antenna with a rotor will be fine. If more tv's , then two antennas with remote control A/B switches at each tv. The 'Pending applications included' shows that WWAZ channel 5 is on the air now or will be soon. So to better understand the best antenna set up , how many tv's will be connected ?
