Old 25-Jan-2014, 1:30 AM   #3
Signal strengths are Strong at your location and are LOS=Line Of Sight.
A antenna system amplifier Is Not Required.
Reception of the UHF channels to the , South East is Easy.
Install a , www.antennacraft.net , U4000 antenna aimed at about 129 degree magnetic compass direction.
Here is how to aim antennas, www.kyes.com/antenna/pointing/pointing.html
Reliable reception of KFMB channel 8 will most likely require antenna aim adjustments.
And the antenna may not be aimed to the , South West , the best reception.
The best reception for channel 8 can be from reflections of the signal from the surrounding area.
Install a , www.antennacraft.net , Y10-7-13 antenna.
Combine the , U4000 antenna and the , Y10-7-13 antenna with a , UHF/VHF signal combiner , Antennas Direct model , EU385CF-1s .
Most Digital Tv's have , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Signal Quality is Important for Reliable Reception.
www.amazon.com
Last edited by teleview; 25-Jan-2014 at 3:48 AM. Reason: Clarify information and typos.
