Old 25-Jan-2014, 12:05 AM   #1
redoc
Looking for OTA advise in UTC (San Diego).
Here is map for my location:
http://www.tvfool.com/?option=com_wr...5b940207c9065c
Antennae will be placed on roof about 25 feet from the ground.
I'm mainly interested in sports channels OTA (basically channel 8 and 69) but would like others although it's not a huge priority.
Now, I'm literally in a tight situation - my potential problem is that there is a very large, very tall building sitting at about 200-215(maybe 220) degrees that would be impossible to get a signal either over or through. I can't really nail down the exact azimuth right now without getting on the roof.
Channel 8 is at 223 degrees; what kind of LOS fudge factor do we get in regards to sandwiched azimuths?
I currently have a dish network sat professionally installed with weighted mount. I want to disconnect the dish and install an antennae in it's place.
Is this doable? If so, what antennae would you recommend?
Thanks,
Paul
redoc is offline   Reply With Quote
