Old 24-Jan-2014, 7:05 PM   #15
Splitters provided by the cable company are fine in just about all OTA systems.
It's unlikely you'll find a 5-way splitter. I'd use a 4-way and feed the shortest runs via a 2-way fed off a port from the 4-way. If needed a Channel Master CM-3410 can be added between the antenna and input of the 4-way.
Satellite grade splitters are not a problem. Diplexers and multiswitches are incompatible with OTA frequencies.
