					Originally Posted by  Trainman9
				At this point I am getting about 40 channels in digital with all the majors in HD. Just can't seem to get WHYY. They broadcast in VHF as does the local ABC station but the latter comes in fine.
 That's probably because WHYY transmits in a directional pattern to the SE whereas WPVI is pretty much circular. Signal could be significantly weaker in strength and/or quality at your location.
See the radiation pattern map
http://www.rabbitears.info/search.ph...&callsign=WHYY
