Reliable reception starts and often ends with the choice of antenna and it's location. The best antenna will fail if it's located where it can't receive a signal with adequate quality. There is more to quality than raw strength or quantity.
I'd rather drink a small glass of clean water than have barrels of polluted water.
Try changing the antenna location. You may need to have some patience mixed with persistence, but it's very likely you can find a location and aim point that provides better reception of the signals that you want.
