Old 26-Jan-2010, 6:51 PM   #3
Michael-60
Local Antenna Livermore
Thanks Mtown.
your advice is very welcome.
another question is what height should the antenna be at. My roof peak is 15feet above ground with a location of maybe 50 feet to TV. The other location is my chimney at 80 feet.
Also my coax is 20 years old.
The pre-amp gives the signals a boost for longer runs or splits.
I see on the chart after the station name is a DT, which I assume means Digital TV?
One confusing item is that KTVU has two listings at 48 (FOX) and 44(2) with a 77 degree spread. We watch 'American Idol' and '24' on our Channel 2 (KTVU-FOX) in Livermore. How can I tell which one it is?
I will be researching the antennas you suggested and where to get them.
thanks - Michael
Michael-60 is offline   Reply With Quote
